MF30 electrical problem
StNick
I have an electrical problem all of a sudden with my MF30. The Ampmeter and the Fuel Gauge no longer seem to be working. The alternator seems to outputting 12.7 volts. Any ideas? Nick Marks, Dublin, Ca.
12.7 volts is about the resting voltage of a fully charged 12v battery (normally 12.6). This suggests to me your alternator is no longer charging. I would expect to see 13.5 to 15v with the engine running if it was charging normally. How original is the wiring on your tractor? Does the ammeter move if you turn the lights on?
Some ideas: Get a test light or voltmeter out and start checking to see if there is power at the ammeter. If there is not, you can work backwards from there to the source. Some possible causes are a broken wire, bad/dirty connection, or other cause creating an open circuit. And of course it is possible, but not highly likely to me, the ammeter failed. The ammeter and fuel gauge issues may well be two different issues as the ammeter should have power all the time and the fuel gauge should be on a switched power circuit (possibly an oil pressure switch). Depending on your alternator there may be a way to manually force output to check to see if will produce required charging voltage. Do you have a manual with the wiring basic tractor diagram, even if it is not right for the alternator? It should cover the fuel gauge and original ammeter wiring.
Thanks for the reply. Yes, I do have the full set of manuals for this tractor and it has a wiring diagram for the diesel version of this tractor. Also, I have a voltmeter (and know how to use it). I am going to do some more extensive troubleshooting. The ampmeter circuit also involves the starter solenoid and I was doing some wiring repairs on that recently so maybe something is not connecting. Also someone pointed out that the voltege I was reading at the alternator could have just been battery voltage so again I need to do more extensive looking.
Thanks for the reply. I need to do more troubleshooting. You are so right about the battery voltage vs. the charging voltage. I need to start the tractor and disconnect the battery and see if the alternator is still putting out. The tractor will run even if the battery is off. There are no lights on this tractor. They were off when I bought it years ago and I have not put new lights on it. The alternator was changed recently so maybe it failed.
Thanks for the reply. This is definitely a diesel unit. It has the Perkins diesel engine (great motor) but I don't see any oil pressure switch in the circuit (I have all the manuals). I need to do more extensive troubleshooting. The circuit involves the starter solenoid and I fixed a loose wire on it recently so I need to look at that some more. Thanks again.
On my 65s the switch appears to be part of the oil gauge. Look for a oil line going up under the dash. I just checked the parts book for a MF 150 diesel and the oil pressure switch is on a tee just below the oil gauge.
Thanks for the reply. I don't see any oil pressure switch in the circuit (I have all the manuals for this tractor. When I get back to the ranch I need to do more extensive troubleshooting. Thanks Again.
It is not recommended to disconnect the battery from a running unit to check an alternator, as was done with generators. The alternator voltage can spike and damage the alternator or the unit's electrical system. Do you know what alternator you have? there may be a way to check its output without disconnecting the battery.
Thanks for the information, and I stand corrected. I looked at the wiring diagram again and there is an oil pressure switch. I'll have to look at my parts manual to see where it is physically. The books and the tractor are at our ranch and we plan on going back out there later this week. Thanks Again Nick Marks, Dublin, Ca
(quoted from post at 18:41:58 05/03/22) Thanks for the information, and I stand corrected. I looked at the wiring diagram again and there is an oil pressure switch. I'll have to look at my parts manual to see where it is physically. The books and the tractor are at our ranch and we plan on going back out there later this week. Thanks Again Nick Marks, Dublin, Ca
Many had a Tee, in the oil line to the gauge, right next to the gauge, so the switch is in the dash right behind the oil gauge.
