MF30 Power Steering
StNick
The power steering on my MF30 seems to work fine when cold but once the tractor warms up the PS seems to go away. The manual says use fluid meeting spec MF M-1129A. I found out that WalMart evidently changet their fluid and the WalMart fluid I added no longer meets M1129A (it does meet M1141, M1143, and M1145) Would this fluid be the problem? I went out and bought some fluid that does meet M1129A and will add it when I can. In the mean time is there anything I can add that would make the PS work better until all the old fluid works it's way out? The only way I know to drain the system is to either pull the PS pump (bolts are hard to get to) or I can try to syphon out some of the old fluid. Any Ideas?
Me and you are having the same issues. I have rebuilt my pump with a new seal kit. Was fairly simple to replace the seals. Might have to flush it out. If yours is a Parker Hannifin pump there is a bolt on the back of the pump that will drain the reservoir in the pump.
Thanks so much for the reply. I will try to drain the fluid. I don't know off hand if my pump has the bolt on it to drain the fluid. I'm not at the property today but I'll go there tonight. I had the pump rebuilt by a Massey dealer not too long ago. I had another dealer's service manager tell me there is a place near each wheel where the fluid can be forced out by loosening a bolt, raising the front end with the loader, and turning the steering end to end. I'll check on that too. I love this old MF30. I can leave it sit for months but it still will start right up but it has the power to do everything I need to do. Sometimes our grass gets up to several feet but I can mow it just fine and the backhoe has plenty of power. Thanks again.
