MF35 injector pump governor spring position
Robert Ga.
I am trying to determine the correct throttle spring position on the fuel injection pump on a 1962 MF35. I have the chart, but the numbers on the pump do not match up - no slash ("/") on the pump as indicated on the chart.
Numbers on the pump:
No. DPA: 3232718
Serial No.: R7324ND
No. DPA: 3232718
Serial No.: R7324ND
Does the pump have a SETTING CODE on the tag? Some do and some don't. If it does post the code. Pumps without the code have it on the spec sheet only.
The DPA number and the serial number are the only numbers on the tag. any idea where I can obtain a spec sheet for this pump?
