MF35/MF135 trans interchange ?
BSer
I have a MF135 with a 3 cyl perkins that had the 6 speed trans go South with several damaged gears. i can pick up a MF35 with a bad Standard diesel,also a 6 speed. Can i exchange transmissions? the 35 is available with the 3 cylinder perkins also. HELP!!!!!!!!!
The later 35 had a Perkins but not the 35 you're looking at. I'm not sure but I think the two engines have different bolt patterns to the trans. Someone on the Massey forum should know for sure. Dave
