Lee Tho
I need to add remote hydraulics to a MF 35 diesel can someone please tell me what I need and how to do this thanks.
The easiest way is to find a control valve that mount to the 3 point hyd system. But that is not really the best way but depending on what you need the hyd for will work
Control mounts in front of seat. You have to remove plate with two bolts on top of housing. It's easy to install and is the best way.Try to take picture tomorrow so you can see what it looks like.
Go to --fergusontractors.org/fena--then Gots & Wants left side page. Bob has a T handle one for $245. If sold he can help you his number is 517-282-1127
Mickey
There are dozens of different installation options as per your request:
Here's an Installation, with Zero to no capital available to install Remote hydraulics:
I purchased a used original MF control unit for $75.00,had to fab a quick lever handle, and lock mechanism:
By NO means the route I would take, if I had had a better budget at the time:
This installation runs a ONE WAY Ram:
There are many other Installations that are MORE USER FRIENDLY...It's about your Budget and preference:
Bob. Owner Operator MF FE 35 X
