I have searched the internet and through the threads but have been unable to locate some information. I am trying to help my neighbor, a disabled military vet, get his machine working properly again. I am mechanically inclined and know how to wrench, but i haven't really messed with tractors or hydraulics much. This has definitely been a learning process. He states that the hydraulics were working fine when he parked it. Now the backhoe hydraulics aren't working, it just whines went the lever(s) is moved. The loader hydraulics still work. What I've gathered is that it has a separate front mounted pump that runs the loader and backhoe with an external in-line filter. I have located what i would consider the location to add hydraulic fluid on top of the right arm of the loader (see attached pic). However, I can't determine how to assess the level of the hydraulic fluid. I did find a hydraulic hose that looks to be supplying the backhoe that has lost the protective rubber (outer sheathing). It is missing where the hose bends and appears to possibly be restricting flow. I thought to: check fluid level, change filter, and replace that hose. Does anyone have any thoughts or able to answer the questions? Thanks
1. Is the place (cap) on the right arm of the loader the place to add hydraulic fluid?
2. Where/how do I check the hydraulic fluid (I know where to check the transmission/hydraulic fluid on the right side of the case inside the cab, but the backhoe/loader hydraulics seem to be a separate system)? Do I remove the silver piece under the cap? Will it matter if I "over" fill it?
3. To remove the external in-line filter, do the hydraulic arms need to be retracted? At this point, the backhoe arms are extended and not working.
4. What is the lever to the right of the seat for? It seems to be immovable.
5. The transmission fluid level is displaying above "full" (the dipstick on the right of the case under the seat). Does this matter or should I drain some out?
Specs:
1975 MF40
SN: 9A 214071
Loader: MF32
Backhoe
3 cyl diesel
Specs:
1975 MF40
SN: 9A 214071
Loader: MF32
Backhoe
3 cyl diesel
