MF40 industrial injectors
Oops
Got the injectors out. Disassembled, cleaned and
new tips installed. Does anyone have the pressure
setting for the 2.5 liter Perkins diesel. Haven?t gotten
the manual here yet.
Thanks you sir. These diesels are new for me. Be glad to have the shop manual here. May not have to ask too many questions.
Spec I quoted was taken from the CAV/Lucas/Delphi spec book. Always tickles me how some are so worried about the EXACT setting, when in most cases it's not that critical. For example, United Technologies/Ambac has 3500-3650 setting for new IH injectors, but they don't need reset unless they fall below 2900 PSI. Screw adjustable injectors can be set closer since they are easier to set. Shim type take more time as they must come apart to change shims.
I figure Perkins would know the optimal settings for their engines. The little bit of a different setting may make a noticeable improvement in engine performance which is what I'm always looking for.
