MF40B Control Cable
Rebrown
I bought an old 40B a few years back and decided to finally install the control cable so I didn't have to get down and reach in to turn it off. The cable I ordered arrived and it is 60" and way too long. I believe I can cut it to fit if I can figure out where the cable is supposed to mount. There are no holes on the instrument panel and no brackets or holes anywhere I could find to mount the thing. Can someone please tell me where that would normally be located, or send me a picture.
On our 30B it's below the dash in the sheet metal to left of the air filter. It's in a square punched hole. In the worst case, you could clamp it to the side of that housing with a bolt and large flat washer
over the sheath, or something similar.
(quoted from post at 20:51:00 06/28/18) On our 30B it's below the dash in the sheet metal to left of the air filter. It's in a square punched hole. In the worst case, you could clamp it to the side of that housing with a bolt and large flat washer
Thanks.. I have a square hole in about that location. I will see if the cable will fit and if I can snake the cable around to the other side and to the injector pump.
