MF40E power shuttle
I'm hoping someone has run into something like this. The power shuttle will not drive for two to three minutes after the tractor is started. Once it starts to work properly it shifts instantly as it should. This was first noticed in winter but only on a cold start (below 20deg F), but now happens warm after a 15 minute shutdown. The oil temp is showing higher than normal on the gauge as well. So far the oil cooler and rad have been cleaned, oil level checked, pump output checked using the manual "quick check" and the vent valve in the pump checked (also removed and cleaned)it meets specs in the manual. The return line filter has been cleaned and the pressure side filter is on order. The pressure filter is the last of my best ideas. Thanks for anything you can add.
