MF50-hydraulic overload?
edabbott
Using my subsoiler in first gear and hit a large root. 3 point stays up when running, only slowly goes down then engine off. no control, goes up as soon as started. Is there an overload reset or did I break something? 1964-s/n 537228 diesel deluxe
I definitely jammed the top link. I just don't know what that caused. My repair manual doesn't cover what constitutes an overload event or if there is a reset capability. Hoping to get some advice before removing the cover. Any help would be greatly appreciated. Ed Abbott
The cover will need to come off you likely knocked off the ferguson bypass protection getting stuck open, the little actuator circled in red must be free to move and could be rusted in place or you hit something hard with the 3pt and it got stuck,
see this post for pictures.
https://forums.yesterdaystractors.com/viewtopic.php?p=10192199&highlight=scoobieguy#10192199
Thank you for your reply. My draft control was frozen solid with rust from years of sitting in the weather before I got recently got it and got it running. I am on track now. Ed Abbott
Thank you for your reply and the very helpful information. My draft control was frozen solid with rust from years of sitting in the weather before I got recently got it and got it running. The position control worked fine and I was not familiar with the draft control and didn't know that it affected the use of a subsoiler. I know now. The pictures you sent will help me when I lift the lid tomorrow. I am quite sure you nailed the problem. Ed Abbott (old man with a younger tractor)
Cover removal.1963 MF 35
Bob..
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto130955.jpg
