MF50 multi power seals?
cgarr
Im trying to find the seals for both the input shafts, the rubber and steel rings. Im having no luck, anyone help who would have these service parts?
The seal is the PTO pinion oil seal this PTO shaft also has the 2 steel oil rings. The main drive input shaft also has 2 steel oil rings.
Craig
This post was edited by cgarr on 01/02/2022 at 02:37 pm.
Where and how have you tried to find them? For the PTO pinion shaft, it appears they are available through Massey Ferguson dealers. Using the online parts book and checking an ecommerce dealer there is a number change on both, the rings and seal. Both current part numbers show as available with prices. It looks like the 186198M1 rings are now 3699909M1 and the seal 192329M1 is now 882296M1. The main drive input shaft rings show as 186581M1 and the seal (inside the PTO pinion) 832205M1 superseded to 883935M4. And several online results are found using the part numbers. No guarantees, but that's what I found.
This post was edited by Jim.ME on 01/02/2022 at 03:53 pm.
(quoted from post at 19:52:30 01/02/22) Where and how have you tried to find them? For the PTO pinion shaft, it appears they are available through Massey Ferguson dealers. Using the online parts book and checking an ecommerce dealer there is a number change on both, the rings and seal. Both current part numbers show as available with prices. It looks like the 186198M1 rings are now 3699909M1 and the seal 192329M1 is now 882296M1. The main drive input shaft rings show as 186581M1 and the seal (inside the PTO pinion) 832205M1 superseded to 883935M4. And several online results are found using the part numbers. No guarantees, but that's what I found.
I only looked online and those numbers you listed were parts I already found, the problem was their list of fitment didnt include the MF50 so I thought it wasnt the right part.
I have everything ordered: thank you
