MF65 gas water pump
nisse
I need to replace the water pump on my Massey 65 gas. Just looked quickly today it looks like it is possible to remove pump with the fan attached from the side if you remove alternator? Is this the best approach? Anything else to know about this job besides it will be a mess? Added screenshot of pump from the parts section I was thinking of ordering.
I do have a press, however the pump with the pulley is only 18 dollars more. Might be worth getting to avoid the extra aggravation. It appears there is 2 different possible impeller diameters though.
I know nothing about Masseys, but on a pressed on hub, you have to press it on to the right location in order to align the fan belt. Even if you get one with the hub already installed, you may need to move the hub before you install the pump, especially where this fits multiple engines.
(quoted from post at 22:00:58 08/15/22) I know nothing about Masseys, but on a pressed on hub, you have to press it on to the right location in order to align the fan belt. Even if you get one with the hub already installed, you may need to move the hub before you install the pump, especially where this fits multiple engines.
And be extremely careful when pressing the pulley on support just the pump shaft. Measure up the old pump first.
