mf65 hyd pump
mbrau
I'm try to remove the hyd pump from top.Has anybody done this? Is there anything I have to remove first I have removed the mp pump already thanks for any help.
I"ve been able to remove the hydraulic pump in a MF 65 from the top (before I read the manual that said you had to split the xmission from the center housing to remove it). Yes, you have to remove the MP pump first. It takes a little fiddling, but you can turn & twist is so it can be pulled out. Not easy, but certainly better than splitting the tractor
pull the p.t.o. shaft out the back first then remove the locating dowel pins either side of the trans housing, then with a twist and turn it will lift out
