MF65 power steering lines
Have you checked with your MF dealer? Have you taken the hoses to a local hydraulic shop to see if they have, or can get, the matching hose ends?
(quoted from post at 20:56:28 02/02/21) Would anyone know of a source for the ps
lines? It's a late model 65 diesel. TIA
Looks like:
PN 190804M92 - pressure line (NLA)
PN 190805M91 - return line (looks like this one might be available)
I'd figure out what thread is on them, buy some adapters to make them a more common fitting.
Or- have someone cut the fitting off and weld/braze an adapter on.
Definitely worth converting it to something more common, though.
Check out this post that was on the Unofficial AC Forum. The fellow needs some power steering hoses for his D15. There are a couple sources/options given in that post that might help you. It won't allow me to post it as a link because it must be considered a "competitor". You will need to copy and paste it into you web browser and delete the * , then search.
https://www.allis*chalmers.com/forum/d15-ii-power-steering_topic178015.html
On my MF 65 the power steering lines use a fitting on the end that is real close to the short nose GM fuel fitting which uses a square o-ring . My brother-in-law has a hydraulic tool which will create that end on steel tube and it seems a good hydraulic shop could add the flex portion. I have also seen a similar end on oil coolers. Maybe someone like Russel has that end which would allow you to made your line out of that braided hose. Check Summit Racing website. I always went to Cathey Company in Lansing Michigan for odd fittings. I don't know if they are still there but they never let me down.
Check with Barry Amaral down there between Renss. Falls and Dekalb Jct. He had/has a couple 65's there IIRC.
