mh 333 three point won't work!
have a 1956 mh 333 with factory three point. The three point won"t go up or down it has oil in it and all the levers and linkages are moving freely any help would be appreciated. Thanks john
What's the weather like where you are? A lot of hydraulics are froze up from water or 'wrong ' fluid for this sorta winter, from the Rio Grande to eastern Canada....
First off,How many hyd.valves do you have?The triples had a Hyd.from Hxxx.There should be a set screw with a lock nut on the side of the valve-cyl.that can be adjusted to turn on or off the 3 point cyl.They tried a system that made the 3 point cyl.move to control the remote cyl.position.It didn't work 3/4 the time.We and most others put a seperate valve in for the remote and didn't have any more troubles.Look at it and maybe if the weather breaks I can get a chance to look on one of mine because they still have all the console metal on them.
