MH 44 Special Thrust Washers
moonliter
In frame overhaul with rings and bearings. Repair manual references to crankshaft end play as being solved with center main flanged Bearing. The bearing replaced was not flanged (.040 under) There were thrust washers on the front. Did not change them. When we ran the tractor had significant knocking due to the crank shifting and hitting the block. Attempted to install flange bearings in center main per repair manual reference but because of .040 under bearing flange would not fit between journals. Crank had not been ground for .040 oversize flange on the bearing. Can we shave .020 off each side of the flange and make it work. Thrust washers are not referenced in repair manual so don't want to mess with them if don't have to. Lots more work and more guessing what we should use. I am open to any ideas and suggestions. Really confusing when we have a different set up than is in our reference material. Help!!
I think that you have a 44 special engine (277) with a 44 (260) crankshaft in it. Same diam. main journals, but the thrust in controlled with the front washers.I was told long ago that this set up would work if you also changes the front main cap along with the crank. How much end play do you have? I"m pretty sure when you have a crank with the thrust on the center the thrust surface is turned to fit the new flanged bearing and obtain the correct clearance. If you have a 44 crank I don"t think you can use a center thrust bearing. The best solution would be to use the front shims to get the proper end play. Without looking in the book, I think the end play is 4 to 8 thou. Good luck!
How do we tell if the front main cap has been changed? My mechanic mentioned that it appeared that crank flange bearing surface had not been turned as it should have been??? If someone was turning the crank to .040 under why would they turn an older crank? I know no one can answer that but the person who did the work and I have no idea who that might be. I'm going to need a lot of luck on this one. Thanks for you thoughts.
I would assume the front main for the thrust washers would have a machined surface facing the thrust washer. The main bearing set with the center thrust is almost impossible to find, that might be why the crank might have been changed or switched to washers in the front.I oh"d a 277 last winter and if not for the internet I wouldn"t have found main bearings for it. I ended up with a 20-20-10 set and had the crank turned to fit the bearings, had the center main cleaned up to fit at the machine shop. If you don"t mind me asking, where did you find a 40 over center main for a 277? If you have a 277 crank with the thrust on the center main I think I would pull it and have the surface turned and properly fit. Once every thing is put back to spec it will last for thousands of hours.
I was attempting to "get by" with an in-frame ring and bearing job on an auction tractor to be used only for tractor rides. It had all new head, ran great but was very loose and drank oil. Found out the crank had been ground after we tore it apart. Also, learned how hard parts were to find. Montis in Chicago is source for hard to find Continental parts but he could only come up with 2 rod bearings and a front and center main .040 under. Also, had the .040 flanged center main. All seemed great until we attempted to install it. Beginning to think it might have been easier to install a V-8 (and more fun in the end)
There were two styles, one had the front thrust, and the other one had the center thrust. It depends on the serial number which one. The cranks will not interchange. I found a NOS front thrust washer on EBAY and grabbed it. I still have the old one, but am keeping that.
I lucked out and an engine machinist came out and looked at my crank and determined that it was machined for the flange bearings, measured the space , machined the flanges on the bearings to fit and all is working great.
Lots of confusion due to someone doing something other than original design. It worked for them but a headache for the current dummy trying to follow manufacturers manual. All done now.
