Mh55 Gear Oil
I am going to change the gear oil in my 1952 mh55. So i believe the gear oil is housed in the pto box, transmission and rear end. Can I drain all the oil through the plug on bottom of the rear end? Then can I refill it all from the top of pto box until in runs out fill hole on side of trans? Thanks for any help!!
That is what I read in my manual too, however I can only locate one fill level plug. Which is why I thought they maybe all shared a reservoir. I will look again and see if I can find another level plug. If so I will fill pto/ trans through top of pto until it comes out trans fill hole and fill the rear end through the level plug on rear end housing (if i can find it). I am trying to avoid removing top cover to fill.
Does anyone have a pic or could explain where the fill hole is for rear end? I can only find the one in the side of the trans, been up and down it a hundred times
