mehorton777
Mice were a problem for years, chewing the insulation off the wires, causing shorts, battery drain, wouldn't start, etc. I installed a sut-out kill switch between the battery + lead and the starter terminal which ended the battery drain problem, but not the cause of the problem. Recently I had Hoober Tractor company install a new wiring harness. Rather than donate the new wires to the mouse emergency food supply, I install a sheet of aluminum flashing between the battery and the wiring panel in the battery box. This eliminates accessibility from the battery box to the wires.
