Miller aead 200 le
I think 3600.The factor rep that came and worked on mine set the RPM with a volt meter in the AUX power tap while welding voltage to 120Volts. I bought one of those several and it was the machine that made me say that I would never own another Miller. It started giving problems at 7 hours and never gave up. It was sent to the local service center 4 times, the dealer did give me a loaner, Miller flew a factory rep in and came to my shop and worked on it, and it never did get fixed. I finally traded it for a Stihl cut-of saw and went and bought a new Lincoln.
I was going to link other thread with the HF engine question but apparently it got poofed. I had linked the manual for the welder there. I went back and found it and will link it again. Unfortunately the trouble shooting section does not list the proper engine rpm it just refers you to the engine owners manual.
Welder manual
I think my Trailblazer idles at 2400 and full speed for welding is 35or 3600 this is with the Kubota diesel in it. Never have had a problem with it so far in 22 years other than the usual maintenance.
I was thinking of making it pto driven . I should have kept my little yanmar tractor I could have swapped the engine on to the welder .
(quoted from post at 15:35:15 09/24/21) I was going to link other thread with the HF engine question but apparently it got poofed. I had linked the manual for the welder there. I went back and found it and will link it again. Unfortunately the trouble shooting section does not list the proper engine rpm it just refers you to the engine owners manual.
Welder manual
Page 19, group 7.7 covers adjusting engine speed and gives rpms.
