Miller Welder With Onan Engine
Critter
I've got the chance to get a Miller welder at a steal, BUT the Onan eingine which is setup on propane needs a major overhaul. The welder hasn't been run in several years I was wondering first is there a way to test the welder to see if it even still works before spending a load of money, and second is the 18hp Onan worth rebuilding or should I be looking for a new engine? I would like to change it over to gas but the local Onan dealer wants over $600 for the new carb.
Thanks for your help!
There is no such thing as working on an Onan cheaply. Their parts are higher than platinum.. I have a NH series and like to have choked when I bought parts to overhaul it. a very few things are available through aftermarket sources, but not much in the way of internal parts.
Yes ONAN's are EXPENSIVE to work on. How do you know the engine needs work. LP will make an engine last for a LONG TIME. I would leave it on LP. Most likely set-up to use a Fork-lift Cylinder as a fuel supply.
I bought a old Wisconsin powered Lincoln DC 180. The engine was locked-up. When I go the engine free ed-up I connected a mill-amp meter to the output leads and cranked the generator over by hand. It generated a little current. I repaired the engine and now use the welder and am going to set-up LP as a second fuel on the engine.
Kent
I forgot to mention that most Onan engines set-up for LP have a higher compression ratio and do not convert well to gasoline.
Kent
Hi Kentb,
Guess I should have explained a little better. The current owner of the welder stripped the threads on 1 of the spark plugs then left it sitting out for several years, the muffler rusted out. I took the heads off a few days ago the cylinders were about 1/2 in. deep in rust and pitted pretty bad. Oh and the oil is milky. Priced a major overhaul kit just over $200.
Thanks for the help
