520 pipefabricator
Just going to satisfy my curiosity urge
here and ask- how much could you safely
deck a ford 8n head?
ot much....it is side opposite spark plug that becomes the problem.. May have to grind the combustion chamber as shown here. If I may ask, why? Those flat heads are so thin & flexible, that when you torque them correctly, the 'warp' flattens out.(quoted from post at 16:41:39 08/16/21) Just going to satisfy my curiosity urge
(quoted from post at 17:10:03 08/16/21)hose flat heads are so thin & flexible, that when you torque them correctly, the 'warp' flattens out.(quoted from post at 16:41:39 08/16/21) Just going to satisfy my curiosity urge
.and when you are done, check for piston to head interference.(quoted from post at 07:48:47 08/17/21)(quoted from post at 17:10:03 08/16/21)hose flat heads are so thin & flexible, that when you torque them correctly, the 'warp' flattens out.(quoted from post at 16:41:39 08/16/21) Just going to satisfy my curiosity urge
I would agree with some caveats. You can easily pull out twists and bends but not waves created by distortion of the casting. And there are other reasons to deck a head.
Macine milling or decking the head creates a distortion free [[u:3b9991a193]b]flat[/b[/u:3b9991a193]] surface with the proper surface finish needed for securely gripping and sealing a head gasket. Unless you are well trained in hand scraping techniques and possess the proper flatness and surface finish gaging tools and a good supply of machinists dye hand finishing is not a viable DIY option Trying to scrape in a head with a hand file and your eyeballs is a recipe for disaster. You can easily wind up with a surface that looks great but has so many humps a camel would be envious.
Fifteeen or twenty minutes to setup and cut a flathead with a surface mill on a milling machine or or surface grinder will get you a reliable flat surface with a 60 Ra finish just like it came from the factory.
TOH
(quoted from post at 11:07:36 08/17/21).and when you are done, check for piston to head interference.(quoted from post at 07:48:47 08/17/21)(quoted from post at 17:10:03 08/16/21)hose flat heads are so thin & flexible, that when you torque them correctly, the 'warp' flattens out.(quoted from post at 16:41:39 08/16/21) Just going to satisfy my curiosity urge
Macine milling or decking the head creates a distortion free [[u:968ac0f7e2]b]flat[/b[/u:968ac0f7e2]] surface with the proper surface finish needed for securely gripping and sealing a head gasket. Unless you are well trained in hand scraping techniques and possess the proper flatness and surface finish gaging tools and a good supply of machinists dye hand finishing is not a viable DIY option Trying to scrape in a head with a hand file and your eyeballs is a recipe for disaster. You can easily wind up with a surface that looks great but has so many humps a camel would be envious.
TOH
had to have the head on Granddads tractor milled being it wouldnt hold a gasket. .010 - .015 is no big deal for piston to head clearance.(quoted from post at 09:04:53 08/17/21)(quoted from post at 11:07:36 08/17/21).and when you are done, check for piston to head interference.(quoted from post at 07:48:47 08/17/21)(quoted from post at 17:10:03 08/16/21)hose flat heads are so thin & flexible, that when you torque them correctly, the 'warp' flattens out.(quoted from post at 16:41:39 08/16/21) Just going to satisfy my curiosity urge
Macine milling or decking the head creates a distortion free [[u:3e418fbb78]b]flat[/b[/u:3e418fbb78]] surface with the proper surface finish needed for securely gripping and sealing a head gasket. Unless you are well trained in hand scraping techniques and possess the proper flatness and surface finish gaging tools and a good supply of machinists dye hand finishing is not a viable DIY option Trying to scrape in a head with a hand file and your eyeballs is a recipe for disaster. You can easily wind up with a surface that looks great but has so many humps a camel would be envious.
TOH
In fact check deck height of all components. I am guessing a .015/.030 skim off the L-head ain't going to be an issue but I have never actually tested that theory :roll:
TOH
(quoted from post at 17:08:22 08/17/21) A couple of thoughts.
When milling a head it is much easier to
clamp to the sides of the head - if
possible.
If you clamp it Down to the table you need
to shim it on 4 corners so you can mill the
bow or warpage out of it. Shimming/clamping
can take a long time to do.
My engine machinist has an interesting
machine. A head resurfacer - built by
Winona Tool
It is a simple flat table with a spinning
grinding wheel about 12? in diameter in the
center of it. Grinds on the face of the
wheel. Turn it on and manually slide the
head back and forth. Adjust the depth of
cut by raising the wheel. Not for heavy
.010+ removal of metal but for a quick
flattening or refinishing it does a great
job rather quickly. When I replaced the
flanged sleeves in a block the flanges were
proud by about 3 to 5 thou. We turned the
block upside down and ground the flanges
till the wheel just kissed the deck. Block
was heavy so I helped slide it back and
forth. Would be the cat's meow on a flat
head that is light weight.
I think you dismiss the use of a file too
quickly. Harry V and I were not talking
about removing metal with the leading edge
like you would on the ways of a machine. A
good, sharp 12 in. mill file will actually
remove a fair amount of material by hand by
draw filing. A new framing square with a
bright light behind it is a pretty good
home brew indiactor of flatness or warpage.
I have never heard of someone decking a
head. Only the block. Have only heard of
someone milling or resurfacing a head. But
maybe...
(quoted from post at 07:48:56 08/18/21) Toh,
A blanchard grinder with a big rotary
table and the grinding wheel above is not
at all what I described in my other post.
I resurfaced a few heads myself - once upon
a time though not with a purpose built
machine.
My first ship was a submarine tender. It
was a repair ship. Had a big machine shop.
We had both a 36 shaper and a 3'x6'
planer. I enjoyed running them and usually
asked for those jobs. Every ship always has
its own small boats. Liberty boats for the
crew and the captain's gig.
When I was aboard all those boats were
still running Detroit diesels. I planed a
couple of heads for our own boats. Once we
pulled into Naples Italy for about a week.
When the fleet found out we had a planer
and could resurface a 671 head guess who
got real busy for a while.
Bet I did at least a dozen of them.
I would dial in and shim the 4 corners. If
they are warped you have to level them the
best you can - split the difference, etc.
An old X71 Detroit head you can clamp them
from the sides so that's how we did it.
Was not complicated at all.
Yes, you could do the job on even a small
mill though maybe not on an inline 6.
HAT!! Your experience ain't got Jack S to do with a flat head iron head Ford N tractor! Geese!(quoted from post at 22:55:12 08/19/21) I recently went through this dilemma on the aluminum head for my 2.5L inline 6 bmw.. not overheated and very little distortion after 200,000 miles... agonized over what diy method I would use to prep it for a week... In the end my machine shop guy took off .007 and left me w a perfect finish for a whopping $60..... yeah that's not free but peace of mind that I won't be buying another $250 worth of gaskets and head bolts plus $50 in fluids and doing another 2 days of wrenchingis priceless....
Granted everything about our old tractors is simpler, cheaper, and easier so the risk of loss is so much less but still the same principal.
This post was edited by Smokeonthewater on 08/19/2021 at 07:58 pm.
WHAT!! Your experience ain't got Jack S to do with a flat head iron head Ford N tractor! Geese!
ail it to smoke on the water, bet he can blow it from either end. :twisted:(quoted from post at 08:38:51 08/20/21)
Anyone got a duck call they can send JMOR so that maybe he can call his Geese?
ey, easy there....I am not the one using the "goofball" name calling! But you do hang your chin out so far as to make you an easy mark. But I will try to pass you by in the future. Have a nice day.(quoted from post at 13:33:32 08/20/21) Why jmor over reacts to these things I can't say, but I think the root of his confusion stems from the classic/ modern view differences...
When I'm replying in modern view I see all replies in chronological order and it's plainly obvious that I'm responding to the line of discussion in hobo's and tim's prior posts...
In classic view it's a mystery as you can't see the other posts unless you click on each one.... A person could easily go back and reread prior posts to understand why I mentioned my totally different engine but that same person could also choose to slobber out some insulting blurb and then exclaim something about large water fowl lol
(quoted from post at 10:51:20 08/20/21)ey, easy there....I am not the one using the "goofball" name calling! But you do hang your chin out so far as to make you an easy mark. But I will try to pass you by in the future. Have a nice day.(quoted from post at 13:33:32 08/20/21) Why jmor over reacts to these things I can't say, but I think the root of his confusion stems from the classic/ modern view differences...
s you like!(quoted from post at 15:47:10 08/20/21)(quoted from post at 10:51:20 08/20/21)ey, easy there....I am not the one using the "goofball" name calling! But you do hang your chin out so far as to make you an easy mark. But I will try to pass you by in the future. Have a nice day.(quoted from post at 13:33:32 08/20/21) Why jmor over reacts to these things I can't say, but I think the root of his confusion stems from the classic/ modern view differences...
How about me JMOR? can I get pass by status too?
...... A good, sharp 12 in. mill file ...
