Mini dozer engine identification help
Baldone
I have a MD 40 mini dozer with a single cylinder engine with the following numbers on the block. EYI8W B11710. The engine has a mucuni carburator BVI8 on it. I have no idea what make this engine is and need help identifying it.
(quoted from post at 17:59:05 09/05/19) I have a MD 40 mini dozer with a single cylinder engine with the following numbers on the block. EYI8W B11710. The engine has a mucuni carburator BVI8 on it. I have no idea what make this engine is and need help identifying it.
Jim, Thank you for the reply.
I understand that?s the engine it called for, but it?s been changed as the engine in the unit has a rental company name on it.
I even called the number on the sticker on the engine, but the company has been out of business for several years.
As mentioned there?s no markings other than the numbers I mentioned in my first post.
A web search shows EY18-3W as a Wisconsin Robin (owned by Subaru now, I believe) model so yours may be a version of that engine. Robins were used on a lot of small equipment (pumps, compactors, etc.) and were a common engine for replacements in some areas.
