Mini gas tractor for 5 year old?
wesleyn1983
Question for you guys. My son is 5 and is Obsessed with anything tractor. He has a 12 volt John Deere tractor but has a lot of interest in gasoline engines and how they work. Is there such a thing out there as a mini gas tractor? Possibly older that we could restore? Thanks everyone!
I came across this video a while back and thought I may have to build one someday. If you go to his main page there are several videos of the tractors working.
Poke Here
Some of the older riding lawn tractor might fit the bill. Or you could go the route of building one like a guy I know does but that can get into some high $$. This guy builds mini tractors that almost look like the real thing but smaller
(quoted from post at 13:55:25 09/29/19) I came across this video a while back and thought I may have to build one someday. If you go to his main page there are several videos of the tractors working.
Poke Here
Yes something like this would be awesome!!
(quoted from post at 14:12:10 09/29/19) Not sure where you are at but I have a couple of older riding lawn tractors I'd part with but I am in Missouri and my e-mail is open
Northwest Indiana. Basically the lowest tip of Lake Michigan.
At 5 my boy graduated to one like this. Mustang Mowette.
I'd suggest one of the older hydro garden tractors such as the Ford LGT Models,Massey Ferguson 14,16,1650 etc,Simplicity Sunstar,JD 318 etc they have a hand operated hydrastatic
drive,some have power steering.
My sons & now grandsons learned to drive a Garden Tractor about that age. I had a couple older model Case, like 220, 222.
Being hydraulic drive, they ony have to deal with one lever. push forward or pull back.
Having been a NW Indiana native, There are hundreds of used riders that can have the mower deck removed easily. These are available on craigs list, or the local
paper for sale adds. From Michigan City to Gary, to Valpo, youwill find what you need for less than 500. (much less if you are willing to fix a little, or do
not care about looks. Jim
The older case mowers are
excellent for that. Tough as
nails and easy to drive and
fix. With the hydraulic drive
they run forever and are
easier and cheaper to fix if
something goes wrong since
they have a regular hydraulic
pump and motor. Here is a pic
of mine.
One option not mentioned here is a modern hydrostatic tractor with a FOOT operated speed control.
Here's why: An old fashioned rider with a clutch, the inexperienced kid has to remember to push the clutch in a panic situation. With a foot-operated hydro control, all the kid has to do is take his foot off the pedal and the tractor STOPS instantly.
Kid falls off one of those old tractors, it just keeps chugging along. Kid falls off a foot-pedal hydro, it STOPS instantly.
This is what I did for my nephews, who don't live on a farm and don't get a lot of driving experience, and they have no issues riding around the yard. Even when one hit a tree, he panicked and his foot naturally came off the pedal. The tractor did exactly what it needed to and STOPPED. A gear drive would try to climb the tree, possibly flipping over on the kid while they fumbled for the clutch, or worse, froze and did nothing.
Once the kid masters driving around something of that size/speed without hitting things and exhibits good control, then they can graduate to a clutch. That's what I'm doing now, putting them on my Cub and letting them get used to clutching to start and stop.
Cub Cadet in the 2005 to 2010 year range. Has a throttle cabe and a hydro tranny. You could wire the throttle to low speed. Seat is adjustable The Vanguard 26 hp v twin motors sound like a Harley.Auto kill if seat is empty. I have 500 hours on mine and have done only oil and filter maint.You can sell the spindles and belt and blades if they are good.
welcome to YT- I'm just north of you, outside St. Joe, MI.
The old Wheel Horse tractors have the styling of antique tractors, are super simple to work on, and were built in South Bend, IN.
Many of the other suggestions are great, as well.
My grandson is 7 and taller than most 7 year olds. He does a great job
driving, but His feet won't reach the peddle on my JD hydrostat. So he
has to sit in my lap, I run the peddle. Also have a two seat go-cart.
Same problem, feet won't reach the peddle.
You may have to build one or modify something to fit your son.
Another note on hydro tractors on most there is no need for a brake the hydro stops the tractor when its put in neutral the BIG exception is the Case hydraulic drive tractors
many of those will free wheel down a hill like its kicked into neutral a real bad design.Later models were fitted with a valve to hold the tractor back.
I spent many hours at a young age on a late model JD B. I would stand and steer and run the hand clutch and throttle and brakes. My uncle sat in the seat making sure I did it correctly.
