minn-moline 670
I am the guy that has the 670 that the hydraulics squeal in neutral.
It has one round lever and three flat.The round being closest to the seat. Is this open or closed centered system???
Also, where are the relief valve or compensator valve located??
Thanks!!
Your system is the open center type. That means that there is flow but no pressure is developed until a handle is operated. Moving the 2 center flat handles either way or moving the right hand flat handle rearward not only operates the valve for that cylinder but also operates the master spool which closes off the free flowing return to the resevoir and causes excess fluid to go through the relief valve. The relief valve is located on the 3 point cylinder side of the valve body and can be seen through the hole under the two small horizontal levers under the seat when the oil is low.
Since your system isn't supposed to develope pressure until you operate one of the valves, I assume that one of them is causing the master spool to be closed when they are in their neutral positions. The master spool is located in the center of the valve body and can be seen through the above mentioned hole when the oil is drained or very low. The 3 point spool is closest to the 3 point cylinder & the 2 remote spools are closest to the handles.
John
Thanks for the info.
The tractor is 40 miles away. And I also have a job in town,so it will be a fews days till I can get to it and look things over
Once I do, I will be getting back to you.
Appreciate it....
