Minneapolis Moline 445
Steiny70
I have a question about a Minneapolis Moline 445 that Im helping a gentleman with. The hydraulic pump that is on the back just below the third link is not working. So I took it off and theres no sleeve/couples connecting the shafts together. So, Im guessing someone has taken this off at one time. Or, is there not a sleeve/coupler needed? Also the three point is not working. Is that because of the hydraulic pump not having all the parts? Im new to Minneapolis Molines and Im not having much luck understanding this tractor. Ive worked on John Deere and Internationals. Could someone help me understand? Thank you!
I would ask on the MM board. I have worked on the pump on a Jetstar and a 335 and both of them had couplings between the shaft and the pump.
Yes there is a coupling between the shaft
and pump. And yes that pump runs the 3 pt.
If you search the net for Agco parts
books, scroll down to guest user, click on
view books. Search for 445, it will be
under White. Works best on a computer, not
very well on most mobile devices.
Thank you! Glad Im not losing my mind on this tractor. Just puzzles me on why its missing.
So, heres another question? Wheres the best place to get the parts?
If you can locate the part number, as stated above, the first place I'd try is an AGCO dealer. Otherwise, there are some other sources. The guys down in the MM forum can steer you in the right direction.
