Minneapolis Moline RTA
Amy Hearnen,
You are looking for part number RE101A cylinder blocks from any model Z or R tractor. They are all alike and even the later ones with the 10A1462, and other, numbers are all the same. Virtually all of the Cylinder blocks from all the Z and R series tractors are all the same.
Right now I have a slight shortage of them in my bone pile too.
Good hunting.
Charlie at
Moline Parts
Dennis P,
When the blocks will not clean up with sixty over pistons, you can still bore them to 3.8 inches (0.174 over) and go with really big pistons. The 3.8 inch bore will still allow you to farm with your tractor and parade it around. 226.8 cubes sounds big, but it still gives a bore to stroke ratio of 0.76 versus the original ratio of 0.725 from the stock bore. If guys can still run these engines with a ratio of 0.8, using four inch bores, I can farm with something less. One fellow put my 3.8" pistons in an R (0.95 ratio) and he is pulling a mower with that tractor. I bet it sounds really smooth.
I just sent two pairs of my Z blocks to the shop to get them bored to 3.8 inches. I would have needed ninety over pistons to clean them up. Even for my own tractors; I can not afford the tooling to get another size piston made. I wish I could afford to make more piston sizes right now.
Unfortunately there is a more pressing need for main bearings, and the factory will no longer make them unless I order a full production run in each size. Gotta' keep those tractors a hummin'. I have the feeling that this spring I will be plowing up a garden that has not been turned in over thirty-five years.
Charlie at
Moline Parts
DennisP,
I did not properly read your post. My head is thinking Z and you are working on an R. I need to get some sleep.
If you need a set of blocks for and R, I might just have what is needed. I just scrapped a tractor with a perfect bore and four nice R pistons in there. I would never break up such a sweet setup for a Z. Drop me a line and I will do some checking Monday. Right now I have to get to work for two twelve hour shifts, this weekend.
Charlie
Thanks, Charlie. I have several blocks that I know can be saved by using the 3.8 pistons. Just finding pistons when I need them is a challenge sometimes. I'm kinda surprised there isn't a car/truch piston out there that could be made to work. I will keep yours in mind. Thanks!
