Minneapolis Moline U
I have run across 2 propane U's for sale, one is according to the owner rebuilt with new tires, has not run in several years (kept in barn), the other is parked outside has not run in several years either. Both are wide front ends. I am told they both will run with some propane and a new battery. I know my description is inadequate, but can anybody tell me what they might be worth? Tractor data says they are 27 hp at the drawbar and 36 hp at the pto, based on the size of the machines I thought they would be closed to 50 hp. Can it pull a bat wing shredder(15ft). Any information will be greatly appreciated.
Tell the owner to get them running if all they need is fuel and a battery. I would think you would need to also work on the distributor and points. The regulator might need work too. Offer $500 each for the tractors as a starting point.
