(quoted from post at 18:05:32 02/13/22) the absolute worst thing you can do is heat something like a spindle and beat on it, the shaft will be mushroomed and you will never get it out.
you have to heat it and move it back and forth which will require lubing it or using wax melted in , once you get it to move freely it then can be heated and driven out.
working it back and forth will loosen the rust, if you get it to twist and move freely you may have to go around the shaft with a flat file and emery cloth to drive it out.
(quoted from post at 19:58:43 02/13/22) Air hammer works for me. Attach the correct sized pouch. It will be out in a few seconds.
