Missing oil filter part critical for operation?
GGBB
Hi: I have a 1944 9n with the original oil filter canister. I seem to be missing the part directly above the filter element canister. It's part # was 9N-9N6885. It looks like it is a sealing spacer of a sort. Is it necessary for today's OEM elements? Thanks....GGBB
GGBB again.....this is the part in question. It could be the new elements have the center gasket as part of the oil filter element and the outer gasket is a separate extra. Was there a metal center piece at one time to join the two gaskets? Hard to tell by the drawing.
No, the 2 gaskets should be seperate.
One like you stated is already on the element, while the other one is separate. That one seals the oil filter cap to the base. It should come in the new oil filter package though.
Number 4 is a separate gasket from number 2.
If you don't put number 4 in, oil will leak all over the engine.
Good luck!
