Hello All:
New member with my first query. I recently acquired my father's 1956 Ford 640 from my brother prior to his death. I brought the tractor home and it seemed to run fine for about a week. Then it started running very rough. I discovered the points were locked up and replaced those and re-timed it. Thought all was good.
Then I noticed the battery was boiling over almost immediately after being started. Not a good thing. I began tracing wires. I have a voltage regulator with L, BATT, & F terminals on the side and I assume A terminal on the bottom. It was wired with the gen A term to the bottom, gen GND terminal to F, gen Field term to L and BATT to the terminal block and then to the ammeter. My understanding this is all wrong. It should be A to the bottom lug, FIELD to F, BATT to the ammeter, GND to ground, and L can either be open or connected to lights and other loads.
I made the changes and polarized the generator by shorting the BATT and F terminals and got a really healthy spark. I saw conflicting information online on how to do this. Some said to short the BATT and A terminals instead.
However, now the generator does not seem to be "generating." I thing it was working before since the battery was overcharging. Is that just because it has not been "excited" yet since the battery is actually overcharged? Is my regulator fried from being wired incorrectly? Bad ground to the GND terminal? Or what?
