down_right
So I am fixing up the wiring on a farmall 504 diesel. I have replaced the alternator with one of those 63 amp fast start" 1 wire alternators that is internally regulated and doesn't need to be excited or anything, etc. i want to upgrade from the key switch and push button/start setup to just an ignition key switch, but am unsure of how to properly do the wiring with this specific type of alternator
There are 4 terminals on the ignition key switch
1) The raised middle terminal: has markings "ST" which I assume is "START"
Is this what connects to the start terminal on the starter solenoid?
2) BATT Terminal (top)
Is this what connects to the starter at the same post as the positive battery cable?
3) IGN Terminal (bottom left)
I have no idea
4) ACC Terminal (bottom right)
This is what I connect things such as the glow plug to? Or for the light switch, this is what connects to either the INST or BATT terminals on the light switch?
I plan to have a couple of those in-line spade fuse things to replace the OEM fuse holder, where in all of this should I splice then in?
