Miter Saw Shopping
Glenn F.
I am shopping CL and Marketplace for a power miter saw for projects around here. I currently just have an old Stanley hand miter saw. A compound saw would certainly be nice but a standard one would probably do just fine. What brand(s) should I look for/avoid? Simpler is better. Quality over gadgets……
Thank you,
Glenn F.
I have a Makita 10" saw I bought more than 20 years ago. ....I don't use it for business, but it still does a lot of work for me.
The yellow Dewalt saws have a good reputation, as well as some models from Harbor Freight.
Don't buy a used saw unless you can plug it in and hear it run. .....Before plugging it in, try "wiggling" the blade to see if the bearings are worn.
A good quality blade will make an inexpensive saw perform well. .....A 60 tooth carbide-tipped blade for doing quality trim work. .....If you'll be cutting mostly 2x dimensional lumber, a cheaper 40 tooth blade will suffice.
I had a Craftsman, that got passed to my SIL, when my grandkids got me a Ryobi compound, sliding miter saw. Haven't had a chance to use the new one yet, but it seems to be well made.
Thank you,
Glenn F.
I have a HF that does just fine. It the type that slides and will do a 12" board.
I've got the HF Chicago radial arm saw that does all the cuts I want. Sideways and slanted, no problem. All saws, including table saws, need to be checked and adjusted so all the angles are exact.
What about this one?
Is this a good saw?
Is this a good saw?
Sears sold a bunch of those saws, and for 80 bucks you can hardly go wrong. Parts might be an issue, but there are a lot of aftermarket parts available for Craftsman saws on eBay. I think Emerson was the manufacturer, the same company that makes the Ridgid brand power tools sold at HD.
Big miter saws have pretty much replaced radial saws, so used radial arm saws are pretty cheap. If you don't need the portability of a miter saw and have room in your shop for another machine, a radial arm saw could be a good solution. I need a portable saw and my shop is full, so I use a 12 inch compound miter non-sliding DeWalt miter saw. It gets a lot of use. If I was shopping today, I'd probably get a slider.
Thank you,
Glenn F.
I've got a compound Dewalt I bought off FB marketplace, and like the saw.
Bought it because it came with a folding roll around stand for a good price.
I don't do that much in the way of woodworking, so the stand makes it nice for getting it out of the way.
Bought a non working Kobalt table saw for $20 just for the stand, mounted my Skil table saw on it.
Space is at a premium for me (isn't it for everybody) and I just don't need things taking up space when not in use.
FWIW
Agreed- a good quality blade will make the difference.
Have a bauer from harbor freight. Works perfect for my projects. It is a 12 inch.
My mistake. It is an admiral brand from harbor freight
