(quoted from post at 16:47:31 08/24/20) Not going to hurt anything. I only keep a 55 gallon drum of Napa Long Life all makes coolant concentrate. It is yellow and mixes fine with anything. Been using it for 10 years with no issues. The only thing I buy specialty coolant for is hybrid inverter cooling systems, I buy premixed in whatever color the vehicle uses.
(quoted from post at 05:16:03 08/24/20) First off, almost all antifreeze is ethylene glycol, although there is at least one non-toxic propylene glycol antifreeze available, <a href="https://www.peakhd.com/product/automotive-antifreeze/sierra-propylene-glycol-antifreeze/">Sierra</a>. Although Sierra has been on the market for decades, it has never really taken off.
The difference between antifreeze types is the additive mix. Traditional (typically green) antifreeze is now called "non-organic additive technology" (NOAT) and the newer stuff is called "organic additive technology" (OAT). There are also variations that mix non-organic and organic additives.
In general, it's best not to mix additive types, but it's not the end of the world if you do. The main problem with adding old school antifreeze to newer stuff (such as Dex-Cool) is that it tends to reduce the long life of the OAT antifreeze to that of NOAT. I keep both NOAT Prestone and OAT Dex-Cool on hand; the Prestone goes into my tractor and the Dex-Cool goes into my various GM vehicles. There is really no concrete evidence that mixing antifreeze types causes problems (such as sludge), but it's not that big of a deal to keep both types on hand.
