MM 206L-4 Engine
Garp
Hello! I am looking for a 206L-4 engine for my 1964 Minneapolis Moline Jet Star 3 industrial. My governor failed and the engine blew up. I live in NY but would be willing to travel (I have a trailer) or pay shipping expenses. Looking for a running engine or cheap tractor I could pull the engine from.
Let me know what you?ve got or if you know of a salvage yard that has Moline?s.
Thank you very much!
Uni motor has old style crankshaft and crankcase is not same but will work. Jet 3 has one piece rear seal as well and 3 bolt flange starter. Same as 445 or MM combines of that late 50's.early 60's era. Have a real good bottom end out of combine but hesitant to use in Jetstar 3. Jet 2 same old setup with 1 bolt starter. Running out of good crankcase's.
Does anybody know if Don Rice in Geneseo NY is still living? I used to buy a lot of MM parts from him. He used to be pretty active on this forum and the jetstar.MM website.
Uni-Harvestor was an implement unit with several attachments like combine,swather,baler and corn attachments.MM/White sold to New Idea in early 60's. First models had one wheel on back and 2 large ones on front. Later models had 2 rear wheels and were brown in color.
(quoted from post at 07:11:06 03/11/20) I thought the Unis all had a V-4 of 206 cu in displacement??
No. the first Unis were a flat head V4 Blocks and heads from ZA.
Then in 55 or 56 Unis with two headlights had blocks and heads from 445. In approx 1960 the Brown Uni (Model S24) came out with a 445 - 4star engine with two steering wheels in the rear.
MMDEL
