just bought a 1957 MM 335. it has been sitting for at least 10+ years the motor was stuck. so i pulled it apart removed the rod caps and oiled the pistons and slowly got them out of the jugs on the last piston i broke a ring the top compresion ring. can i get buy with just putting a new ring in that or do i need to rering all 4 pistons.
I agree with Clint. Make sure there isnt a ring grove or ridge on the top of the cylinders also or you may bust a piston.
i can see a small ring around the tops of the cylinders. i think i am going to rering it as far as i can tell it is all factory bore. i had to pull all the valves and clean them up but they show only small amount of use.
thanks
also i am looking for the coolent pipe that goes between the 2 cylinder blocks. if any one knows where to buy these please let me know or if you have one send me a email with price. thanks guys
does any one know where i can get the coolent pipe that runs between the 2 blocks. it has a pipe that runs from the water pump to the first block then there is one or whats left of one going from the first block to the second block. thank you
