MM 445 p/s leaks into rear diff
MMMOST
MM 445 the power steering fluid leaks into the rearend. not exactly sure what to look for to fix this.
The most likely cause is the seal on the hydraulic pump shaft is worn out. You will probably find that there is a groove worn into the shaft as well. The worn shaft can be repaired with a repair sleeve that you should be able to get at a seal and bearing supplier.
