MM (M-5) Fuel Pump
Does anyone have any info on a M-5 fuel pump. I would like to know what they use and how big it is? Is it easy to advance the fuel for more power? How much more can I get out the 336 C.I. motor??? Thanks guys
It is a diesel,right?I,ll bet its a Roosa-master,they're pretty easy to turn up.If the tractor is not turbocharged,you're wasting your time(and money)Naturalasperated engines cant get enough air to burn the extra fuel.
The earlier diesels used model PSB Bosch inline pumps. They switched to a Roosa Master DBG pump in "61 or "62. You can switch from the Bosch to the RM but you would have to change all of the injector lines.
As far as more power, most of the pulling guys use the gas/ LP versions. My M5 has G1000V Jugs & heads, I think it ran 72 hp with a fresh pump.
Thank You for your reply!! G1000V. Anymore tricks you wish to share with me? :)
How light were you able to get your M-5 down for weight? I totally want to strip it. 72 H.P. would be a good number for 4500 to 5500 classes :)
