MM P3 grain drill
1370rod
Does anyone know what needs to be done to change the
setting from low to high gear?
Look at the drive gears on either end of the drill. You will see gears with 2 rows of teeth on them. Pull the bolt out and flip the gears over so they use the other set of teeth.
