Can someone tell me the model (S500, S600, S700) and year of this MM 5 bottom 16 inch plow? Also some information on the harrow like accessories beside it.
Sent from my iPhone
As you most likely know it is the same as an Oliver 565 which was made from the early1960's until the early 1970's. Going by online pictures with ID I would say it is a S600 in MM numbering. A lot of plows did not have serial numbers until the 1970's and have no idea where to look on that plow but suspect it lacks a SN.
Should be mfg. part numbers on moldboards and shares ( points l ). those numbers will be necessary to proceed with someone that has access to the data about your plow .
