rmf1066
It's me again with more questions about my UB. It's getting close to fire up and there is a couple of things that I'm having a hard time figuring out. First there are two lines on the left side of the block one that goes to the oil pressure gauge and the other one on a rectangular plate that I don't know where it goes or does. The other question is the tractors hyd pump was missing when I got it all it had was the spacer between the dis and pump with a oil line going to it. Can I take the spacer off and block off the line or do I need to put a cover on the spacer and keep the line. Thanks Ryan
the line from the block should be the oil pressure guage line. the other can be plugged ( in the cap). Put a plate over the hydraulic pump hole and keep the oil line. It puts oil onto the parts that runs your distributor. Not good if they are dry
The line in pic 1 on the plate is a vent/breather line goes to the top of the hyd reservoir under the front of the fuel tank,the other one I would personally plate where it is at and leave that line,just my opinion.
Thanks for all the help. This tractor was in pices when I picked it up and my first Moline. Thanks for all the help again!!! Ryan
