hello..
was wondering if you could give me some help advice
I've a red nose uts 1941 and when I was using it I started to loose the clutch snap on the lever..it became easy to slip in then became hard to near impossible to snap the lever back so basically it's constantly driving and not disengage..I had to crash it into first gear to get me back to where I needed to be..
I removed the side cover and there was a big gap between the 3 yoke pads and the solid discs where you normally adjust...I pulled the pin and took up the slack yet still no change as I though it just needed adjusting..
it doesn't snap in or out ..just seems to hit a solid point and no over centre...I backed the yoke off and the solid disc came back and was loose..the toothed plate seems along way in the flywheel ,not sure if that's normal. but either way I've issues..is it best to split the tractor to deal with it as after a good fiddle didn't seem to make any difference..
are new plates available or what do you think is the best plan? is it a hard job to split them? I've heard of needing big long bars ??
thanks
thanks
