MM UTU for sale
*IHMMJD*
I have a 45 u for sale. It is a solid block with a starter, distributor, and a good one piece manifold. Sat in a shed for 15 yrs and is stuck. Would make a good puller $800
Saved this from a scrapper!!
Here are the pics
Alot of mixed up parts. No 1945 U with KEF motor had distributor all magneto. The hood is off a 1953 or newer U. To make hood fit either hood around radiator neck had to be cut or rad changed. Has later gear pattern not like older red nose U's. Wouldn't take much to convert back.
That distributer is not a MM set up. It is a Delco conversion that Delco made for all makes to bolt on where the mag was mounted. You are right a lot of mixed up parts!
MMDEL
