Mm zb hydraulic cover
pvictor15
the hydraulic cover leaks on my zb. Have had it welded up many times but doesn't last. Anybody else have this problem? Anybody know where I can find a good used one?
Gordon
[qu5thote="pvictor15"](reply to post at 09:44:31 06/26/22) [/quote]
No its the cover thats bolted to the pump with 2 attached hydraulic hoses
The triangular flange that has a pipe and a hose coming out of it? Im betting it cracked where the hose is screwed into it? Most of
the time it happens from over tightening it. Make sure you get one to match your hydraulic pump as they are different between the
two pumps that were used. The round pumps were Eaton brand whereas the flat sided ones were replacement Webster brand pumps. The
Webster flanges I believe were 1/4 turn of the flange so there would be 2 bolts towards the top and one on the bottom. The Eaton
ones were one bolt on the top and two on the bottom.
Yep its leaking where I screwed in the hydraulic hose and yep I may have over tightened it. Any ideas where I can find another?
Thank you
If it has two hoses and is bolted to the pump it should be as Allan says, one hose and a return pipe. Then somebody has made some changes. I am questioning what you have, maybe aftermarket or farmer setup. MM original should be a 3 corner plate with 3 bolts. I do have one that takes two hoses off a UNI tractor. And I may have MM one for a ZB if Chris doesn't. We need to see pictures to help you out.
MMDEL
(quoted from post at 08:08:48 06/27/22) If it has two hoses and is bolted to the pump it should be as Allan says, one hose and a return pipe. Then somebody has made some changes. I am questioning what you have, maybe aftermarket or farmer setup. MM original should be a 3 corner plate with 3 bolts. I do have one that takes two hoses off a UNI tractor. And I may have MM one for a ZB if Chris doesn't. We need to see pictures to help you out.
MMDEL
I will get some pictures tonight when home from work. It is triangle, 3 bolts and a bottom hose and pipe above that. Pretty sure its stock.
