ernestmm
- Location
- Fairfield, MT
My mmg is not circulating water. It has that big thermostat housing kinda like on the gvi that I can't find. Has a bypass tube from there to the pump. Deleted both cause I can't find a thermostat. Water didn't circulate before and won't now. Water seal in pump with spring was replaced. Opened it up again (there is a big squeak) and how much end play should shaft have. Its all apart- impeller is knife edged compared to the spares I have setting around. Going to replace shaft, impeller, whole front pump housing, seals and bushing with the parts tractor stuff that I know work. Will that fix it? My basic question is how much wear can be on that impeller? ?
