model 800 oil pump
Robert Barr
I purchased a 1957 model 800, 172 ci, I noticed that the oil pressure was high, i dropped the pan and discovered that a 100 psi oil pump had been installed, should i change this back to a gear type or is this pump ok?, It has above 80psi at cold start-up and 60 to 70 after warm up. no oil blow-by or smoke. it still has bolt-on type oil filter.
Drop the pan. The oil pump has a bypass spring that sets the max pressure. There may be a shim under the spring. Or you can maybe find a different spring (from an old oil pump maybe).
I would probably just use 5w30 and be happy.
jb
Thanks John, I have 10w40 in it now, will use 5w30 on next change. i saw were the bypass spring is located, I took the capscrew off in hopes to inspect but there is a smooth pressed in cap or seal covering the access to the spring, can i remove and reuse this cap?
