model 850 oil inlet
luna630
Thanks for all your help. I was replacing valve cover gasket and found small copper tube laying flat inside. One side has a long rocker arm inlet tube made of steel firmly placed but the other rocker arm shaft oil inlet is missing. Some one tried to use a copper tube and it fell out. I can get a brake fluid line at the parts store but I do not know how to keep it from falling out. I hope some one else has solved this problem. It is the shorter of the two oil inlets about 1/4 inch diameter I believe. I need some help so I can put the valve cover and gasket on. THANKS!
