Model A flywheel A3264R
Rich Taracka
I"m in search of a flywheel and the big flywheel nut for a Model A. The existing, cracked flywheel has the number A3264R on it.
Thanks,
Rich
When you say big flywheel nut ? does yours measure appox. 5" and square 1/2" thick solid steel ? if so you have a taper lock fylwheel on there. If that nut is a stamped tin hex shape it should still be avail. from Deere.
If you have a taper lock type very likely a std. one won't tighten up. Search the archives for Allen Machine as they make the taper locks.
