Model A Fuel shut off
Yes only problem with old sediment bowls is sometimes you have to get the packing so tight, then you can not turn the shut off valve, then they still want to drip. I get new sediment bowls from steiners tractor parts.
Yes, you can get valve stem packing from most hardware stores. It comes in several sizes.
I like the teflon type.
Slide the hex nut back against the valve T handle. Use a 3 inch piece of teflon pipe tape. twist the tape into a thin string. Wrap the string on the shaft and reinstall the nut. tighten just enough to stop the leak. Jim
For one thing, the originals were back seating. If not completely open, they would leak. So make sure you open it all the way. Otherwise, I have also seen suggestions of waxed dental floss and a small o-ring for packing.
