model number - need help- harry ferguson
Lora Frick
have the following info from tractor:
data plate on left side on motor E-151977 w/ a 20 underneath the 77.
on left side transmission: 3 16 can't read rest.
other numbers TO-4024
data plate on instrument panel: TO-48116,
tractor doesn't have the air intake assembly, nor can i tell where canister would hook on.
Currently there is no assembly after the intake of carburetor,
just the opening. Man had a sock taped on with electrical tape w.
here hose should go.
Can't order any of it until I have correct model..
I have another Harry Ferguson, its assembly mounts on to the instrument panel & vent w/ 1/2 moon w/ screen.
Does the air filter just have a cap???
Maybe a picture on correct mount?
You have a 1951 TO20, the other tractor is a TO30, based on the description of the dash panel. On the engine plate you should see z120 on the 20
and z129 on the other. Nearly identical except the 30 has the bigger engine. Look on eBay for used parts or source out to tractor salvage you may find
the air cleaner there.
(quoted from post at 08:50:29 09/18/21) You have a 1951 TO20, the other tractor is a TO30, based on the description of the dash panel. On the engine plate you should see z120 on the 20
This post was edited by Lora Frick on 06/26/2023 at 03:19 pm.
