MarkWarden
Would anyone know the correct size, stroke and dia. Hydraulic cylinder for the lift cylinder on the Mohawk 1360 shredder? I can not find any info on this shredder.
It's common to put spacers on the cylinder to limit how far you can lower the mower. They're not necessarily there because the cylinder is necessarily wrong.The cylinder that is on it now isn’t the correct one. Someone has limited the stroke by putting spacers on the shaft. This still was not correct and it has damaged the cylinder connection point on the shredder. I’m rebuilding that and was trying to load the correct cylinder so it does not happen again. Thanks!!!!
I used a 3.5' x 8" cylinder to lift the running gear and it worked fine. It's a little over-rated for what you need, but a larger diameter cylinder means it moves slower, so it is not so touchy when you use it.Would anyone know the correct size, stroke and dia. Hydraulic cylinder for the lift cylinder on the Mohawk 1360 shredder? I can not find any info on this shredder.
No, that would indicate one of two things: Either the cylinder is too SHORT, or someone backed the mower into heavy brush, hit something immoveable like a stump or boulder, and kept shoving until the wheels folded up and ripped the cylinder loose.It was bent / ripped away on the shredder side. Cylinder stroke internal must be to long?
